TPS25200-Q1: TPS25200-Q1
Part Number: TPS25200-Q1
Can I connect the "~Fault" pin to "Enable" pin in order to lockout disconnection mode when fault appears first time rather then re-try mode?
  • Hi Ran,
    I don't think this will work. Please allow me time till end of this week to verify this. I am checking if the device will keep the FLTb low when the EN is low.
    Arush
  • Hi Ran,
    I have verified this. When the EN goes low, the FLTb pin will go back to high level so using FLTb to keep the EN low won't work. Can you share your requirements. Maybe I can recommend another device which have latch off variant.
    (Operating voltage/current, reverse current blocking, is automotive part required?)
    Arush
