BQ35100: Enquiry about BQ35100
Part Number: BQ35100
Hi, TI expert
I have a question about BQ35100.
BQ35100 has cell chemistry based on Primary Lithium.
Can you explain the difference between it and other common fuel gauges?
I want to know what is optimized and how to use it correctly.
Could you please explain the contents, such as whether the profile is pre-loaded?
Please check. Thank you.
  • Hello Grady,
    The BQ35100 is specifically designed to work with primary battery cells, other gauges in our catalog are compatible with rechargeable battery cells. Depending on what type of battery you have, the gauge has different modes to use.
    For how these modes work, I would recommend reading over the TRM.
    Adrian
