When conducting thermal analysis, I need the values of the Maximum Junction Temperature and Thermal Resistance parameters. However, they are not listed in the data sheet. Can I get both values?
Hi Kim,
I will check internally and get back to you.
Arpita
Hi Kim,
It does not look like we will provide thermal parameters for Module as it is not a discrete device and kind of a PCB in itself.
We guarantee operation till 85C with thermal derating mentioned in the datasheet. So as long as it meets customer's temp range... It should be good with performance.
Arpita
