Using a PTH08T250W module designed a regulator, with the help of WEBENCH Tool. Input is 12V, Output is 0.85V, 40A.
My query 1) Would like to use Inhibit/UVLO pin as ON/OFF function for regulator. As per my understanding from Datasheet Table-1
If Inhibit = 0 , output of regulator turns OFF
If Inhibit = 1, Output of regulator Turns ON. is this my understanding correct ?
My Query 2) Control signal to Inhibit pin is generated from power sequencer IC ISL87072IBZ. This generates a open drain signal. Is this ON/OFF function works or not please suggest
