Other Parts Discussed in Thread: TPS25751, BQ24401, BQ25792
Hi, how can we configure the BQ25720 to charge NiMH cells?
The product spec says it supports NiMH chemistry among others, but the data sheet doesn't mention NiMH even once.
I also can't find any app notes on charging NiMh cells with this chip.
1. Does this chip support NiMh or is there an error in the product spec?
2. If NiMH is supported, how does it terminate charge cycle? Does it use Delta V? Temperature rise rate detection? Constant voltage? Trickle charge with a timer?
3. Can it support more than 4S since NiMh has lower voltage than Li+?
