Hi TIer
My customer use tpsm843a26 in system.
Currently test we found a issue:
1. If output current large than 13A, the ripple voltage will be large suddenly. If I increase output current , the output voltage will reduce to 0.4V. If reduce the output current , the Vout will increase.
2. we try to change C889 to 3.9pF and the phenomenon is consistent. (not working)
Could you help check the sch and give some suggestion?
Thank you very much.
