TPS7H6003-SP: Operating switching frequency range.
Part Number: TPS7H6003-SP
The datasheet for the TPS7H6003-SP doesn't have listed a maximum/minimum switching frequency range for this device. We are planning to use this device with the Independent input mode enabled.
I understand that the upper frequency is limited by the propagation delay and rise/fall time of output signals.
The Pspice simulation indicates that there should be no issues running at ~380KHz. If we are planning to run faster, then we just need to change the bootstrap resistor and capacitor to accommodate the recharge time.
Thanks for taking the time to answer this question.
Horacio
