Other Parts Discussed in Thread: BQ25792
For below test item, is possible to help us modify VIF file?
Project Name |
SGN-TP-12242401 IEC 62680 on BT 20 |
Company |
Test Log |
Test Item |
Port A |
Remark |
Merged USB PD3 CTS |
LeCroy |
Fail |
0114_1st round |
Type-C Functional |
Ellisys |
Fail |
TD.4.7.1-3: PUT must sink no more than 100 mA. |
LeCroy |
Fail |
TD.4.7.2: The PUT does not remains in AttachWait.SRC for 500ms. |
Below is VIF and JSON file. thanks!
<?xml version="1.0" encoding="utf-8"?> <vif:VIF xmlns:opt="http://usb.org/VendorInfoFileOptionalContent.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:vif="http://usb.org/VendorInfoFile.xsd"> <vif:VIF_Specification>3.33</vif:VIF_Specification> <vif:VIF_App> <vif:Vendor>USB-IF</vif:Vendor> <vif:Name>VIF Editor</vif:Name> <vif:Version>3.11.0.0</vif:Version> </vif:VIF_App> <vif:Vendor_Name>TI</vif:Vendor_Name> <vif:Model_Part_Number>Toprock20241212</vif:Model_Part_Number> <vif:Product_Revision>1.0</vif:Product_Revision> <vif:TID>10306</vif:TID> <vif:VIF_Product_Type value="0">Port Product</vif:VIF_Product_Type> <vif:Certification_Type value="0">End Product</vif:Certification_Type> <vif:Product> <!--Product Level Content:--> </vif:Product> <vif:Component> <!--Component 0: Port A--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;Component--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:Port_Label>A</vif:Port_Label> <vif:Connector_Type value="2">Type-C®</vif:Connector_Type> <vif:USB4_Supported value="false" /> <vif:USB_PD_Support value="true" /> <vif:PD_Port_Type value="4">DRP</vif:PD_Port_Type> <vif:Type_C_State_Machine value="2">DRP</vif:Type_C_State_Machine> <vif:Port_Battery_Powered value="true" /> <vif:BC_1_2_Support value="1">Portable Device</vif:BC_1_2_Support> <vif:Captive_Cable value="false" /> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;General PD--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:PD_Spec_Revision_Major value="3">3</vif:PD_Spec_Revision_Major> <vif:PD_Spec_Revision_Minor value="1">1</vif:PD_Spec_Revision_Minor> <vif:PD_Spec_Version_Major value="2">2</vif:PD_Spec_Version_Major> <vif:PD_Spec_Version_Minor value="0">0</vif:PD_Spec_Version_Minor> <vif:PD_Specification_Revision value="2">Revision 3</vif:PD_Specification_Revision> <vif:SOP_Capable value="true" /> <vif:SOP_P_Capable value="false" /> <vif:SOP_PP_Capable value="false" /> <vif:SOP_P_Debug_Capable value="false" /> <vif:SOP_PP_Debug_Capable value="false" /> <vif:Manufacturer_Info_Supported_Port value="false" /> <vif:Chunking_Implemented_SOP value="false" /> <vif:Unchunked_Extended_Messages_Supported value="false" /> <vif:Security_Msgs_Supported_SOP value="false" /> <vif:Unconstrained_Power value="false" /> <vif:Num_Fixed_Batteries value="1">1</vif:Num_Fixed_Batteries> <vif:Num_Swappable_Battery_Slots value="1">1</vif:Num_Swappable_Battery_Slots> <vif:ID_Header_Connector_Type_SOP value="2">USB Type-C® Receptacle</vif:ID_Header_Connector_Type_SOP> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;PD Capabilities--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:USB_Comms_Capable value="false" /> <vif:DR_Swap_To_DFP_Supported value="true" /> <vif:DR_Swap_To_UFP_Supported value="true" /> <vif:VCONN_Swap_To_On_Supported value="false" /> <vif:VCONN_Swap_To_Off_Supported value="true" /> <vif:Responds_To_Discov_SOP_UFP value="false" /> <vif:Responds_To_Discov_SOP_DFP value="false" /> <vif:Attempts_Discov_SOP value="false" /> <vif:Power_Interruption_Available value="2">DC Power Only</vif:Power_Interruption_Available> <vif:Data_Reset_Supported value="false" /> <vif:Enter_USB_Supported value="false" /> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;USB Type-C®--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:Type_C_Can_Act_As_Host value="false" /> <vif:Type_C_Can_Act_As_Device value="false" /> <vif:Type_C_Implements_Try_SRC value="false" /> <vif:Type_C_Implements_Try_SNK value="true" /> <vif:Type_C_Supports_Audio_Accessory value="false" /> <vif:Type_C_Is_VCONN_Powered_Accessory value="false" /> <vif:Type_C_Is_Debug_Target_SRC value="false" /> <vif:Type_C_Is_Debug_Target_SNK value="false" /> <vif:RP_Value value="2">3A</vif:RP_Value> <vif:Type_C_Port_On_Hub value="false" /> <vif:Type_C_Power_Source value="2">Both</vif:Type_C_Power_Source> <vif:Type_C_Sources_VCONN value="true" /> <vif:Type_C_Is_Alt_Mode_Controller value="false" /> <vif:Type_C_Is_Alt_Mode_Adapter value="false" /> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;Product Power--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:Product_Total_Source_Power_mW value="36600">36600 mW</vif:Product_Total_Source_Power_mW> <vif:Port_Source_Power_Type value="0">Assured</vif:Port_Source_Power_Type> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;PD Source--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:PD_Power_As_Source value="37000">37000 mW</vif:PD_Power_As_Source> <vif:EPR_Supported_As_Src value="false" /> <vif:USB_Suspend_May_Be_Cleared value="false" /> <vif:Sends_Pings value="false" /> <vif:FR_Swap_Type_C_Current_Capability_As_Initial_Sink value="0">FR_Swap not supported</vif:FR_Swap_Type_C_Current_Capability_As_Initial_Sink> <vif:Master_Port value="false" /> <vif:Has_Invariant_PDOs value="true" /> <vif:Port_Managed_Guaranteed_Type value="0">Managed Capability</vif:Port_Managed_Guaranteed_Type> <vif:Num_Src_PDOs value="4">4 Src PDOs</vif:Num_Src_PDOs> <vif:PD_OC_Protection value="true" /> <vif:PD_OCP_Method value="0">Over-Current Response</vif:PD_OCP_Method> <!--Bundle: SrcPdoList--> <vif:SrcPdoList> <vif:SrcPDO> <!--Source PDO 1--> <vif:Src_PDO_Supply_Type value="0">Fixed</vif:Src_PDO_Supply_Type> <vif:Src_PDO_Peak_Current value="1">130% IOC</vif:Src_PDO_Peak_Current> <vif:Src_PDO_Voltage value="100">5000 mV (Factor = 50)</vif:Src_PDO_Voltage> <vif:Src_PDO_Max_Current value="300">3000 mA (Factor = 10)</vif:Src_PDO_Max_Current> <vif:Src_PD_OCP_OC_Debounce value="0">0 msec</vif:Src_PD_OCP_OC_Debounce> <vif:Src_PD_OCP_OC_Threshold value="390">3900 mA (Factor = 10)</vif:Src_PD_OCP_OC_Threshold> </vif:SrcPDO> <vif:SrcPDO> <!--Source PDO 2--> <vif:Src_PDO_Supply_Type value="0">Fixed</vif:Src_PDO_Supply_Type> <vif:Src_PDO_Peak_Current value="1">130% IOC</vif:Src_PDO_Peak_Current> <vif:Src_PDO_Voltage value="180">9000 mV (Factor = 50)</vif:Src_PDO_Voltage> <vif:Src_PDO_Max_Current value="222">2220 mA (Factor = 10)</vif:Src_PDO_Max_Current> <vif:Src_PD_OCP_OC_Debounce value="0">0 msec</vif:Src_PD_OCP_OC_Debounce> <vif:Src_PD_OCP_OC_Threshold value="286">2860 mA (Factor = 10)</vif:Src_PD_OCP_OC_Threshold> </vif:SrcPDO> <vif:SrcPDO> <!--Source PDO 3--> <vif:Src_PDO_Supply_Type value="0">Fixed</vif:Src_PDO_Supply_Type> <vif:Src_PDO_Peak_Current value="1">130% IOC</vif:Src_PDO_Peak_Current> <vif:Src_PDO_Voltage value="240">12000 mV (Factor = 50)</vif:Src_PDO_Voltage> <vif:Src_PDO_Max_Current value="167">1670 mA (Factor = 10)</vif:Src_PDO_Max_Current> <vif:Src_PD_OCP_OC_Debounce value="0">0 msec</vif:Src_PD_OCP_OC_Debounce> <vif:Src_PD_OCP_OC_Threshold value="217">2171 mA (Factor = 10)</vif:Src_PD_OCP_OC_Threshold> </vif:SrcPDO> <vif:SrcPDO> <!--Source PDO 4--> <vif:Src_PDO_Supply_Type value="0">Fixed</vif:Src_PDO_Supply_Type> <vif:Src_PDO_Peak_Current value="0">100% IOC</vif:Src_PDO_Peak_Current> <vif:Src_PDO_Voltage value="300">15000 mV (Factor = 50)</vif:Src_PDO_Voltage> <vif:Src_PDO_Max_Current value="244">2440 mA (Factor = 10)</vif:Src_PDO_Max_Current> <vif:Src_PD_OCP_OC_Debounce value="0">0 msec</vif:Src_PD_OCP_OC_Debounce> <vif:Src_PD_OCP_OC_Threshold value="244">2440 mA (Factor = 10)</vif:Src_PD_OCP_OC_Threshold> </vif:SrcPDO> </vif:SrcPdoList> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;PD Sink--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:PD_Power_As_Sink value="15000">15000 mW</vif:PD_Power_As_Sink> <vif:EPR_Supported_As_Snk value="false" /> <vif:No_USB_Suspend_May_Be_Set value="false" /> <vif:GiveBack_May_Be_Set value="false" /> <vif:Higher_Capability_Set value="false" /> <vif:FR_Swap_Reqd_Type_C_Current_As_Initial_Source value="0">FR_Swap not supported</vif:FR_Swap_Reqd_Type_C_Current_As_Initial_Source> <vif:Num_Snk_PDOs value="1">1 Snk PDO</vif:Num_Snk_PDOs> <!--Bundle: SnkPdoList--> <vif:SnkPdoList> <vif:SnkPDO> <!--Sink PDO 1--> <vif:Snk_PDO_Supply_Type value="0">Fixed</vif:Snk_PDO_Supply_Type> <vif:Snk_PDO_Voltage value="100">5000 mV (Factor = 50)</vif:Snk_PDO_Voltage> <vif:Snk_PDO_Op_Current value="300">3000 mA (Factor = 10)</vif:Snk_PDO_Op_Current> </vif:SnkPDO> </vif:SnkPdoList> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <!--;Dual Role--> <!--;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;--> <vif:Accepts_PR_Swap_As_Src value="true" /> <vif:Accepts_PR_Swap_As_Snk value="true" /> <vif:Requests_PR_Swap_As_Src value="true" /> <vif:Requests_PR_Swap_As_Snk value="false" /> <vif:FR_Swap_Supported_As_Initial_Sink value="false" /> </vif:Component> </vif:VIF>
