Dear Support,
Our company using since several years part TLC59116IPWR. Shortly we have problems with this part that the LED connected to IC is burned (damaged). Nothing is changed in the design.
The LED we are using is the HSMA-C120. I tried several things and the problem is with a specific batch of this IC. IC marked wit 14KG4 (I think this is the batch (manufacturing)number or is this wrong?) have this problem.
I replaced the IC with a new one with 97KG4 and the problem is solved. Is this a known issue? Is this number like 14KG4 the manufacturing number? I did not find this at your website or datasheet.
Thanks in advance.
Ron.
