TPS92641: Please help to debug process
Part Number: TPS92641
Hi Team,
Could you help to debug what is abnormal in below debug log?
Thank you!
TPS92641排查记录 (1).pdf
Josh
  • Hi, Josh
    Our expert will reply you late.
  • Hi Josh,
    I have gone through the document you attached but do not clearly get what is the problem you are facing. Please kindly provide detailed information, for example -
    • Detailed description of your problem.
    • Which node do you measure when you get those oscilloscope capture?
    • There are three schematics in the document. Which one should I refer to?
    • What does "Peripheral parameter modification" mean?
    Steven
