I am looking for a way to upload an SREC file to a BQ78350-R1 from a custom PC application. I would like the end result to be the same as when the SREC is uploaded using bqStudio. i.e. I need both the instruction flash and the data flash to be programmed.
In the past, Matt Sunna on this forum has offered example Python code which shows how to achieve this. I recently contacted Matt via a private message, requesting a copy of the example code. He said that someone on this forum will be able to help. Please can someone kindly send me a copy of the example Python code which shows how to upload an SREC file to a BQ78350-R1?
Please can you also point me towards the documentation which describes the SMBUS command sequence for uploading an SREC file to a BQ78350-R1 device?
Robert
