Other Parts Discussed in Thread: UCC27714
I would like to assume driving two MOSFETs in series without a pulse transformer using a single PWM IC (UCC28711). In this case, if the parasitic components of the PCB and the parameters of the MOSFETs are assumed to be identical, that is, in an ideal case, will the voltage distributed across the MOSFETs be evenly split into 1/2 during turn off in a flyback converter?
The image has been created for reference to aid understanding, and the PWM IC I will be using is the 28711.
Here, Q1 and Q2 are operated simultaneously by a single PWM IC as per my intention in the question.
