LMG3100R017: parallel connection for higher current
Part Number: LMG3100R017
Can LMG3100R017 be connected as parallel connection for higher current?
If yes, what is expected issue and what additional circuit is needed?
Thanks.
  • Hi David,
    Yes, LMG3100 can be paralleled for higher current output. The main concern is the skew in current distribution due to inherent difference between propagation delay and layout asymmetry. But, if we have symmetric layout, most of the concerns can be mitigated.
    We have built a board with 6x parallel half bridges configured as buck/boost stage. We will get some initial results in early Feb.
    Can you let me know the customer, who is willing to use LMG3100 in parallel configuration?
    Madhur
  • thanks for your support.
    Customer is bettercell for battery test.
    Now they are using discrete solution but I'm promoting integrated solution.
    Thanks.
