So when is the PMID supply used, and as per the datasheet, it is used for backup mode. If we take the output from the SYS pin, there won’t be any issue, right? and
When I remove the main USB 5V supply from the PD controller, the battery charger IC will provide 5V through the battery? (our battery voltage is 3.7V(3.7V)). In that case, our output will come from the SYS pin, right?
