Other Parts Discussed in Thread: TPS65263,
I simulate your tina ti model of TPS65263. According to startup power sequence at datasheet, i cannot find true enable times. How can we enable in different times. EN pin tied to the Vin with resistor divider and I understand that EN pin voltage must be larger than 1.2V. Can you give me an application example for adjusting enable sequence?
Thanks.
