BQ79616-Q1: Digital Reset FAULT_PWR1[AVDD_OSC]
Part Number: BQ79616-Q1
We observe a FAULT_PWR1[AVDD_OSC] fail after performing a digital reset.
For example, this occurs after executing a digital reset (writing 0x02 to 0x0309) when writing an OTP page.
In this case, following the reset, the OTP_CUST1_STAT register contains 0x8F, which we understand indicates success.
Another example would be a digital reset performed during normal operation.
According to the documentation, this failure is described as occurring only during the transition from sleep to active mode.
However, a digital reset is documented to transition from active mode back to active mode?
Could you kindly confirm if this behavior is expected and if everything is functioning as intended?
Thank you in advance!
Stefan
