TPS7A4501-SP: TPS7A4501HKU/EM
Part Number: TPS7A4501-SP
Having trouble using this a s a negative regulator.
  • Hi Brandon,
    Would you be able to share the details of how you're trying to implement the negative regulation configuration and where you run into issues?
    In case it would work for you we do have a space-grade negative LDO, but it has lower rated radiation performance than our full QMLV-grade devices and I'm not certain what your operating voltage and load specs are.
    Sarah
