Hi Team,
RFBT recommendation is 100k as per datasheet.
Is it ok to retain higher resistance value for feedback resistors?
Vidhya
Hi Team,
Vidhya
Hi Vidhya,
For RFBT, it would be ok to use a higher resistance as long as it is less than 1 MOhm. Still I would recommend to keep it in the low hundreds of kOhm range as higher resistance makes it more susceptible to noise.
For SYNC/MODE it is recommended to keep it close to 100 kOhm itself.
Niranjan
HI Niranjan,
So can use 100K Ohms for RFBT and RFBB values used similar to Table 8-1
but to generate 1.05V, RFBB has to be 2Mohms/Open.
Vidhya
Hi Vidhya,
For the 1.05V case I would recommend to keep the total series resistance below 1M. So something in the range RFBT = 20k-40k, RFBB = 400k-800k would work.
However, if you do not need 1.05V exact you can leave RFBB open to get VOUT = 1V.
Niranjan
Hi Vidhya,
I am closing this thread for now. Feel free to reopen if you need further assistance.
Niranjan
