Other Parts Discussed in Thread: USB2ANY
Hi TI team,
Currently we are using TPS6521905 in our design, for programming the chipset we are planning to use
TPS65219-GUI — TPS65219 graphical user interface
Below are the queries that we mainly have.
1. As we are going to program the IC which is assembled on our target board, we just want to ensure that the outputs of the LDOs and switchers inside the PMIC are not enabled untill the initial programming with the required voltage settings is loaded to the NVM. Please confirm on the same
2. For programming using the GUI, can we use any default USB to I2C converter or any specific converter is needed?
