Other Parts Discussed in Thread: TMS570LS0432, TPS65300-Q1, TPS653860-Q1
I am contacting you for technical support on microcontroller and PMICS issues.
We are planning to use the TMS570LS0432 microcontroller from TI in a design project we are conducting.
The PMICS recommended for this microcontroller on the TI site is TPS65381A.
However, we have used this controller and PMICS in a different project in the past years. Since the BUK9213-30A recommended in the datasheet for the FET transistor, which is one of the TPS65381 peripherals, is not in stock,
The BUK9207-30B was used as an alternative. However, in the current situation, we see that there is no stock for both transistors and their production does not continue.
Since the circuit will need to be used for many years when the project we are conducting is completed, the production life and stocks of the products we will use should be relatively problem-free.
Currently, we are looking for both a PMICS alternative to TPS65381A and a BUK9213-30A MOSFET alternative.
Accordingly ;
- Can you help us if there are products you can recommend as an alternative to the BUK9213-3A MOSFET recommended in the technical datasheet?
- If there are products that you think can be an alternative to TPS65381A, can you help us?
- There is a statement in the datasheet that the TPS65300-Q1 product can be a PMICS alternative in TMS570 products, but we could not reach the sample circuit or application, I would like to ask for help in this regard.
Thank you very much in advance for your help and I request your feedback.
