TPS54531: Thermal Vias filled or not filled?
Part Number: TPS54531
Should the thermal vias for this design be filled or not filled?
I have seen some thermal vias on power pads which have a custom solder stencil which does around the vias. This footprint specifies the solder stencil over the thermal vias. Does this not allow solder to be wicked into the via?
I am hoping to avoid having to fill the vias to save cost on the PCB fabrication.
Dimitri
