Are you saving the learned parameters onto your host MCU as the battery is cycled? Otherwise when you reprogram the initial golden image onto the gauge, you are programming the parameters for a brand new battery not a deeply cycled one, so it will take a cycle for the accuracy to converge as the gauge relearns the parameters specific for the battery.
Jonny.
We are currently not saving the learned parameters to our host MCU, Do we have to save it to our host MCU or does it happen within the fuel gauge?
Why should we save it to MCU?
we have a provision for charging the battery onboard in our PCB so it never goes out of power (we only reload the golden file onto the fuel gauge if we have a power-on reset)
anyways we don't see the "learning" part happening thus we are getting non-reliable readings of SOC
please let us know if you need more info
You are not, for example seeing Qmax Cell 0 update, or any of the resistance values?
Jonny.
