TPS56C231: PG behavior coupled with EN pin
Part Number: TPS56C231
Hi Team,
is the PG pin coupled with the EN pin? If enable is pulled low will the PG be also low even if the output voltage is within the PG windows (above 93%)? This can make a difference in the power down sequence when the output voltage ramps down slowly.
Simon
