Hi all,
The TPS55289 has a thermal shutdown feature.
Is it possible know when a thermal shutdown has occured?
Do we have access to the registers in thermal shutdown mode? (to the all register map)?
Thank you.
BR,
Kavita
Hi all,
Thank you.
BR,
Kavita
Hello Kavita,
According the description in the datasheet https://www.ti.com/document-viewer/TPS55289/datasheet#GUID-CD745FE3-85AA-4F4D-AA9A-8A5391A6B5FE/TITLE-SLVSF01T5657623-47 the internal registers are unchanged in thermal shutdown.
Brigitte
Hi Brigitte,
But does the thermal shuthdown mode prohibit access to the registers?
thanks,
KR,
Kavita
Hello Kavita,
In general thermal shutdown does not block the communication to devices, but I have to say that I am not the technical expert of this device. Please wait until tomorrow for getting an answer from the technical expert.
Brigitte
Hi Kavita,
When thermal shutdown is triggered, all internal registers values will remain unchanged, it will not prohibit access to registers.
BRs,
Bryce
Hi Bryce,
Thank you
Is there a way to track wheter a thermal shutdown has occured?
KR,
Kavira
Hi Kavita,
The answer is no. The customer may need to add external solution to monitor the board/device temp.
BRs,
Bryce
