Other Parts Discussed in Thread: BQ40Z50, EV2400, BQSTUDIO
Hello, I have found several topics on the subject but we couldn't fully understand how to resolve the issue.
During production, we need to serialize each bq40z50 with a different serial number. The software assigning the serial numbers is running on a server, so the ideal solution is to use a command line tool to program the SREC file first and send the serialization command after.
The first question is how to write the SREC file with a command line tool (or writing our own tool, if any documentation is available). On the website we found what looks like the proper tool:
BQ-BATTERY-PROGRAMMER-SW
but it doesn't recognize the hardware (EV2400). We read that the EV2400 is not compatible with this tool.
THe manual procedure of using bqStudio to upload the srec file and then going manually to the datamemory tab changing the serial number and the date, it works but it's very time consuming and prone to errors and duplication.
I have also tried the other tool: bqProgramming, but it crashes with an error that looks common to other users. Probably, also this tool has not been updated for a while.
Do you have any idea / reccomendation?
Thank you
Kind regards
Andrea
