Other Parts Discussed in Thread: TPS4812-Q1
I would like to use MOSFET (Q1) VDS for current sensing of the battery power line. Is it possible to use TPS1210-Q1 with 2A charge/discharge current?
Nishie
Nishie
Hi Nishie,
Yes, you can as this device has dual gate drive which allows for charge and discharge applications however there is no reverse current protection (TPS4812-Q1 does have this protection).
Rishika Patel
Hi Rishika-san,
Thank you for your support.
Could you confirm if my understanding is correct?
1. TPS1210-Q1 can sense the discharge current of the battery by MOSFET VDS, but it does not have reverse current protection for discharge.
2. TPS4812-Q1 can sense the discharge current of the battery by MOSFET VDS. And it has reverse current protection for discharge.
Nishie
Hi Nishie,
Yes, your understanding for 2 is correct. For 1, although the device will allow current to flow in the reverse direction, it will not technically sense it and it will not respond which can be a risk for the system; also, for any negative voltage not within the specified range, it is recommended to have a TVS diode to protect your system.
Rishika Patel
