Hello TI team,
In case of the Motor driver system supplying from load switch TPS48111.
As the motor generates energy through regenerative braking or free-wheeling, the energy sent through a load switch to the battery.
I think, if INP is holding high at that time, the regenerative energy can be pass back to back FET to the battery.
TPS48111 sense output current by shunt resistor(R_SNS), If shunt resistor detect reverse current level, does it okay?
Thank you.
