Overcharging will affect battery life.
NiMH battery suppliers recommend that overcharging be defined as charging above 1.5V.
BQ25172 datasheet: Vout_OVP: 1.7V.
Does TI have any other suggestions for this part?
Hello Tom
We would need to look at switching charger. What is the battery pack configuration?
Hi Tom
If you do not require the TS function it could be configured to COOL range using a resistor vs NTC. To give you a 1.5V OVP setting.
What is TI's Vout_ovp testing method?
Unit will monitor the voltage at OUT, if it exceeds OVP threshold charge is suspended until voltage decreases.
