TPS63000: [Design Review] Low noise power supply for EEG device
Part Number: TPS63000
Other Parts Discussed in Thread: TPS631000, TPS631010, TPS631011, TPS7A20
Hello everyone,
Im working on the circuit of power supply for EEG device need lowest noise on rail.
The main power will start from battery( lithium 3.7V) or USB_C connector for charging, have a topology as below:
USBC - Battery charger----- Battery lithium
                                      ------ Buck boost converter to 5V ---> LDO to 2.5V
        ---> LDO to 3.3V
        ---> charge pump to -5V --> LDO to -2.5V
*Buck boost to 5V
* Charger:
*LDO to 2.5V
*LDO to -2.5V
*LDO to 3.3V
My purpose is choose low noise and low drop LDO for using in battery application.
So, please help to review and give the recommendation.
Thank you
