UCG28826: Can the secondary side use diode rectification?
Part Number: UCG28826
Hi team,
The secondary side of the UCG28826 is recommended to use a synchronous rectification method for the SR Controller, but is it okay to change it to a diode rectification method?
Kyohei
    I have not had a chance to look into this due to other priorities and customer support.  I will try to look into this tomorrow for you.
  • Hi Kyohei,
    From the UCG28826 perspective, there is no issue, but from the USB PD Tolerance perspective there could be as VOUT would drop more with a diode as a function of load current than with the SR controller.
    My understanding is that the USB Type C PD standard has tight specifications on output voltage.
    I hope this answers your question.
