TPS7H1101A-SP: Input/Dynamic Capacitance
Part Number: TPS7H1101A-SP
Is there an input capacitance (Ci) and dynamic capacitance (Cpd) available for the following part TPS7H1101A?
Thank you
    Can you help me understand the context behind the parameters you listed and what you intend to use them for? I want to make sure I understand correctly what you're asking for.
    We do generally have recommendations on external input and output capacitance for our power ICs, but it sounds like your inquiry may be following a different thread.
    Sarah
  • Hi Sarah. Thanks for your response.
    We're trying to use the numbers to calculate the dynamic power and establish proper de-coupling for each device.
    We haven't specified internal/parasitic capacitances for these devices. Regardless, these would generally be dwarfed by even the minimum we recommend for external decoupling.
    Sarah
