Part Number: UCC2897A
Hello, I have two questions to ask:
1.The attached figure shows measured waveforms under different load conditions. It appears that during the medium-load condition, the output duty cycle seems limited and unstable. This issue does not occur under light-load or heavy-load conditions. It doesn’t look like it's caused by CS pin or VDD protection. Do you have any other suggestions for inspection points?
2.Currently, under medium-load/heavy-load conditions, the output voltage drops and doesn’t recover to the set voltage. Could this be due to insufficient DC gain in the loop compensation?
thanks,
JJ
