TPS55288: USB c controller
Part Number: TPS55288
Other Parts Discussed in Thread: TUSB320, TPS65987
Hi, I'm building a system using TPS55288 with a stm32 microcontroller, the device is working well,
I need to modify the output voltage according to the USB cc lines, I tried the TUSB320 but it can't tell me what the requested Voltage is...
I found STUSB4710 that seems to do the work but I want a TI IC for that because the IC is not commonly available,
can you recommend an IC? Does the FUSB302 can tell me the requested voltage? I didn't find it in the datasheet
Thank you
