Hi
When Vin = 3V but lower than the output set value can the device still output 300mA ?
Hi
Thank you for your question.
What do you mean by the input is lower than the out?
If the input is less than the device, the device will go into dropout mode and therefore not regulate to the desired output voltage.
Hope this helps!
Hannah
Yes, you should still be able to, but you will not get the desired output voltage you are looking for.
