Other Parts Discussed in Thread: EV2400, BQSTUDIO, BQ27421EVM-G1B
ASUS BSP team have some questions would like to consult us.
Quicky summary their questions as below and kindly feel free sharing your comments for our reference.
1. For BQ27421-G1 technical reference spec, it do not describe how to W/R CHEM ID process & register (Not including standard/extend CMD into specifications)
Could you please share with us how we can operate it ?
2. For other competitors use the BQ27421, do they usage TI default golden image or implement their own parameters to write process ?
Basically , we were survey GitHub repository and found out simple BQ27421 function but not including write CHEM ID in this section.
If guest had usage, relevant kernel code should be uploaded it. Am I correct ?
3. For BQ27421-G1 devices, is it only can using Parallel battery or Series battery also can be used ?
In Parallel battery module, Are there any limit Parallel number in battery module?
what would you recommend when we use Parallel battery modules?
Thanks!
Alice Fan
