Other Parts Discussed in Thread: TLV758P
Comparing the recommended maximum output capacitors of the TPS7A15 and TLV758P,
we found that the TPS7A15 recommends only 22µF,
which is significantly lower than the 220µF recommended for the TLV758P。
Why does this difference exist?
What happens if the total load capacitance of TPS7A15 larger than 22µF, such as 100µF ?
Thank you
Ferry
