TPS54541: Handling Power Good (PG) Pin in TPS54541
Part Number: TPS54541
We are designing a 24V/5A power supply using the TPS54541 with a 28V input supply. We do not require the Power Good (PG) functionality in our design.
Could you please confirm if it is safe to leave the PG pin floating, or should it be pulled high/low for proper operation?
Thanks in advance.
Sivam Natesan
