We are currently experiencing problems when testing our boards with the LM60430DRPKR buck, on some of which the output voltage is not as expected.
We suspect that this is due to a problem with the soldering of the BUCKs, caused by the solder paste leaking through the thermal vias of the thermal pad (we've been able to verify this by properly rebrazing the defective BUCKs).
What do you recommend to prevent solder paste leakage ?
Thanks in advance
Samuel
