LM3414HV: Multiple LM3414 with common Current set resistor
Part Number: LM3414HV
I have 4 LM3414HV driving 4 colored LED strings.(RGBW). The current needs to be the same for all four.
Can I use a single RIADJ resistor and connect all the IADJ outputs together. If so would the calculation of RIADJ be the same as the datasheet or 1/4  for the value..
Thanks for you help.
Colin
