Part Number: TPS7A57
I have high current requirement for one of the sensitive applications and I am planning to use two TPS7A5701RTER LDOs in parallel to fulfill current requirement.
I was planning to design this application as per TIDU421 application document by TI where Opamp is used for balancing the outputs.
But in TPS7A5701RTER datasheet, there is one application mentioned in page 65-66 where Opamp is not considered when connecting two LDOs in parallel. As per my understand , since this has SNS pin and REF pin for current sense, there is no need of Opamp.
Or you recommend using Opamp when we use two TPS7A5701RTER in parallel as per TIDU421?
Bharati
