Hello, expert.
I encountered a problem when using tps92520. I changed the output capacitance of TPS92520 from 1UF to 4.7UF when rectifying EMC.
My current application is just a string of LED, current 800mA, PWM dimming will be used, dimming frequency is 215hz,LED series connection will only turn on and off at the same time. I looked at the manual and wrote that the value of capacitance should be paid attention to in the application of pixel beam or matrix LED load.
Please help me check whether there is any risk in the change of capacitance or what problems should be paid attention.
