Hi Team,
Is it possible to leave FLT and AUXOFF of TPS259470ARPW open to reduce current consumption?
Hi Team,
Hi Iwai-san,
Yes, these pins can be left open if not required in the end application. You can also use weaker pullup if you want to reduce the current leakage through these pins when they go low. Internally these pins are open drain pins.
Arush
