UCD74111: Fusion Digital Power Designer
Part Number: UCD74111
Other Parts Discussed in Thread: UCD9222,
We use the Fusion digital power designer tool to program 2x core voltage regulators UCD74111 with the UCD9222 regulator.
We used version 7.10.1
Under Monitor, where you can set up different plots,
the graphs for the warning & faults limit are no longer displayed in the plot.
In the previous version 2.0.40, these were displayed graphically.
Where are these limits switched on graphically.
Torsten
  • Hi Torsten,
    When Fusion has loaded and Monitor tab is selected (1), make sure to check the different graphs to be displayed in the top left (2) before attempting to poll data (3).
    (you may need to click the screenshot to view it in full resolution)
    Let me know if this helps.
    Kind regards,
    Nick Z
  • Hi Nick,
    The measurement data is displayed as you described.
    The limits and warnings are missing. See image from version 2.0.40
    Torsten
  • Hi Torsten,
    You're right, at first glance that does look odd. Let me contact my team that supports Fusion software and ask them to take a look. Just a heads up, this might take up to 48 hours to hear a response.
    Kind regards,
    Nick Z
  • Hi Torsten,
    It appears from your screenshot a couple items are not populating. We're looking to test your configuration file and see what may be the issue. Could you share your project .xml file? You can do so using File --> Export --> Project File
    Since this is a public forum, I'm sending you and email so we can follow up on that thread.
    Kind regards,
    Nick Z
