TPS7H4010EVM: Max temperature
Part Number: TPS7H4010EVM
Other Parts Discussed in Thread: TPS7H4010-SEP
What is the max temperature range of this eval board?
  • Hi Erick,
    The TPS7H4010EVM was only designed and tested for operation at 25C in open air.
    While the device (TPS7H4010-SEP) on the board is rated from -55C to 125C, the passive components and PCB are generally not selected with the same temperature range, and the board is not tested across temperature.
    Andy
