UCD9222 configuration
Other Parts Discussed in Thread: UCD9222
HI All ,
We are using UCD9222 device on our board. We understand that it needs configuration to generate required output voltages.
What will be the default outputs generated by UCD9222 when it is powered ON ..i.e on a fresh chip recieved from factory ? Will it generate some default voltage without being programmed?
Can the device be programmed over PMBUS when the EN1/EN2 pins pulled LOW ?
-Anil
