Other Parts Discussed in Thread: TPS7A33
Hi team,
I’m writing to check do you have another version that is p2p with UA79M05CKVUR(TO-252) and could support operating temperature of -45-125C ? Thanks.
Lillian
Hi Lillian,
We unfortunately don't have anything p2p to UA79M05CKVUR that will support negative voltage and -45C to 125C operating temperature. What is the application that requires -45C, if you're able to share? Typically -40C would suffice as a lower bound, so I'm wondering if this is a special application.
Based on your feedback, I can try to find an alternative option for you.
Kelsey
Hi team,
Sorry that is a typo, -40 is ok for our industrial use case.
Do we have P2P for -40C to 125C ?
Lillian
Hi Lillian,
The closest option that will fulfill the -40C to 125C requirement is TPS7A33. Note that TPS7A33 is not p2p to UA79M, has a higher current rating, and is lower noise.
Kelsey
