Other Parts Discussed in Thread: AM625
Hi Support team,
We designed a PCB with the AM625 paired with the PMIC TPS6521903. During board development, the PMIC output failed during the power-up process. Based on the PMIC power-up sequence measurements, we found that the outputs of LDO1, LDO3, and LDO4 failed, and BUCK3 had no output at all. Is this issue caused by abnormal LDO outputs, or is it due to the failure of BUCK3?
Is there any way to obtain the PMIC logs to identify at which step in the process the issue occurred?"
Let me know if you need more adjustments.
