UCC2895: PSFB detailed analysis
Part Number: UCC2895
Hi Mike,
is there any application notes/articles covering the detailed mathematical derivation of the PSFB  converter topology.
can you please share.
Keviv
    I searched ti.com and could not find a paper on derivations of the equations for a phase shifted full bridge (PSFB).  You might be able to find this in power supply design text books.  I did find some technical material you will find useful in regards to the operation of PSFB and the design of PSFB..
    I found this presentation on ti.com that goes through the operation of a PSFB and how it works.  https://www.ti.com/video/5045319944001
    The following link will bring you to an application note that goes through the step by step design process of a PSFB using the UCC28950/1.  It has all of the equations that are needed to design a PSFB. There is also a link to an excel design file in the application note that goes with it.  It uses the same equations as the application note.
    https://www.ti.com/lit/pdf/slua560
    Thank you for interest in Texas Instruments (TI) products.  If you have a related question, please click the "Ask a related question" button in the top right corner. The newly created question will be automatically linked to this question.
