UCC27524A: UCC27524A
Part Number: UCC27524A
Other Parts Discussed in Thread: ASH
PCN#20240626001.1
おいて、
    1. 評価用サンプルにつき
    評価用のサンプルをいただくことはできるでしょうか。
    (場合によっては、製造工場ごと、値付けのサンプルなどをお願いする必要が出てくる可能性もあります。)
    1. 電気特性の規格が変更になった理由を教えていただきたい
    今回の設計変更により、従来品と特性が変わった?
    従来の量産品の特性の実情に合わせた?
    チップ工場の違い(TIDFRBDM6)によって、特性に違いが出る。
    組立工場の違い(ASHMLA)によって、特性に違いが出る?
    1. 従来の購入数量(およそ2年ごとに最終発注量(2500p)を購入)から、「当社には従来の製造工場で製造した部品を供給していただきたい」
    という要望を出した場合、対応していただけるかどうか。
  • Hey,
    I am providing the TI Translated version of this for others knowledge and clarity.
    PCN#20240626001.1
    Come on.
    Per evaluation sample
    Can I get samples for evaluation?
    (In some cases, it may be necessary to request a sample of pricing for each manufacturing plant.)
    Please explain the reason for the change in the electrical characteristics standards
    Has the characteristics changed from the conventional product due to this design change?
    Was it adapted to the actual situation of the characteristics of conventional mass-produced products?
    Different chip factories (TID, FRB, DM6) have different characteristics.
    Is there a difference in characteristics depending on the difference in the assembly plant (ash, MLA)?
    From the traditional purchase volume (final order volume (2500p) purchased approximately every two years), "We would like to supply parts manufactured in our traditional manufacturing plants."
    If you make a request, will you respond?
    Due to the PCN, the device underwent quality, parametric, and characterization testing and that is why the spec changes are seen. These changes are reflected in the datasheet in the revision history and also in the PCN. The cause of these changes are outlined in the PCN document.
    If there are further questions, please send me a friend request and we can discuss via private message.
    Thank you,
    William Moore
