Dear TI Team,
I am currently working with the BQ76952 and have encountered an issue regarding the I2C communication with CRC enabled. The current setup on our EVM Board uses I2C communication without CRC, but I found in the TRM that enabling CRC is possible by setting the Com Type register to 0x11.
I followed the procedure and used BQStudio to change the Com Type register to 0x11, but when I sent the command to read 0x14 (Cell 1 Voltage), the data returned was still a single word without CRC.
Could you please help me understand why the CRC is not being applied even after setting the Com Type register to 0x11? Is there something else that needs to be configured or a different setting in BQStudio to enable CRC functionality?
Thank you for your support, and I look forward to your insights.
